Bowtie block help
Old Apr 11, 2007 | 07:45 PM
FastEddiesIROC's Avatar
Bowtie block help
The motor in my camaro doesnt have a dip stick hole. I was puzzled when i discovered this. I didnt build the motor so i wasnt aware of what block they used so i didnt know at the time. Anywho.....I ran the casting number 10051184 and it came up as a bowtie block. When I was reading about it it said that the oil dipstick hole is not drilled. why not?? I hate the fact i cant check my oil. Arnt there SBC oil pans that have the dipstick hole right in the pan? There is a aftermarket Mildon 7qt pan on it now so i'd like to replace it with one simular Any suggestion?? Thanks
Old Apr 12, 2007 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is it driver's side only, or does it have the dipstick boss on both sides?
I thought some early Nova pans had the dipstick directly to the pan, but a search on Summit didn't show any such part.
Maybe it's time to go dry sump. . .
Old Apr 12, 2007 | 04:36 PM
Re: Bowtie block help
I had the car on a lift and you can see on the passenger side of the block there is a bulge where the oil dipstick would go into but no hole is drilled. I've never ran anything with a dry sump set up. Are they good for running on the street, how exactly do you hook it up and what all would i need??
Old Apr 12, 2007 | 10:06 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
why couldnt you just drill it? not like it is going to be rocket science... you would just need to do a test run you know add exactly 7 quarts and see where it comes up on the dip stick then add another 3/4 quart for oil filter and your golden right?
Old Apr 13, 2007 | 04:35 PM
Honestly thats the first thing that came to my mind, i will have the motor out this spring when I go to spray the engine bay so i might as well do it then
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
