Hydrobooster.
Old Apr 12, 2007 | 08:15 AM
Durango_Boy's Avatar
Car: '98 Durango, '77 Vette
Hydrobooster.
Are you guys with Camaros as nuts over these Hydroboosters as the guys over at the C3 Corvette forum? Being a GM brand it'd probably be just as easy to install a Hydrobooster in a Camaro or Firebird as it is in a Corvette. Just looking for opinions.
Old Apr 12, 2007 | 08:42 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Hydrobooster.
I'm going to install one in my RS and C3.
Old Apr 12, 2007 | 09:30 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Hydrobooster.
what is it?
Old Apr 12, 2007 | 09:46 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's a brake booster that's operated off of the power steering pump pressure rather than vacuum. Especially helpful in high overlap cam and supercharger applications. Developed for use on diesel vehicles.
If you search for "hydraboost", you'll find more info and some pics.
Old Apr 12, 2007 | 10:27 AM
chesterfield's Avatar
Car: Pontiac
Re: Hydrobooster.
I know you prefer calling it "hydraboost", but it is called Hydroboost by the manufacturer. It might be a better search term to use.
Old Apr 12, 2007 | 10:38 AM
five7kid's Avatar
Yeah, I've got this technical retentive compulsive disorder thing - "hydraulic boost" -> "hydra-boost" -> "hydraboost" makes sense to me. But, that's just me.
Search both, then.
Old Apr 12, 2007 | 04:27 PM
ljnowell's Avatar
Re: Hydrobooster.
Its ironic that someone posted this, as i am currently involved in installing hydroboost on my car. I got the whole setup including lines from a chevy truck at the wrecking yard, its a fairly straitforward installation, and pretty cool to boot. Just make sure you get your pushrod length right. If you block off the vent port in the master cylinder, it will get ugly quick, at least as soon as the brake fluid gets hot.
Old Apr 12, 2007 | 06:13 PM
Re: Hydrobooster.
I do have a packet of information I put together for all my C3 buddies. It's in a ZIP folder so if you're interested in learning more or maybe getting one just PM me your email address and I'll email the file to you.
Old Apr 12, 2007 | 10:28 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Hydrobooster.
fastcarmo@hotmail.com please
Old Apr 12, 2007 | 10:45 PM
Re: Hydrobooster.
Gotcha bud, it's on the way. Let me know what you think or if I can help you at all.
Old Apr 13, 2007 | 04:25 PM
Re: Hydrobooster.
Keep the PMs coming. I've only had nine or ten requests for this stuff.
Old Apr 15, 2007 | 08:32 AM
Re: Hydrobooster.
Bump bump, the Mac Dad'll make ya, bump bump. The Daddy Mac'll make ya, bump bump.
Old Apr 15, 2007 | 09:06 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Re: Hydrobooster.
I PM'd ya.
If no one minds, how much did the swap cost you?
Old Apr 15, 2007 | 09:13 AM
Re: Hydrobooster.
Originally Posted by 327???
I PM'd ya.
Total setup for $300 - $400 depending on if you make your own lines or buy them, and if you need a different master cylinder.
Old Apr 15, 2007 | 09:18 AM
Car: Pontiac
Re: Hydrobooster.
The f-body master cylinder won't fit will it? I thought the base was too large,I could be wrong.
Old Apr 15, 2007 | 09:19 AM
Re: Hydrobooster.
The master should fit just fine pattern wise, but you'll need a '77 master or later as they changed the snout and pin depth and lengths.
