I hate lifters...
Old Apr 12, 2007 | 06:20 PM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
Transmission: 700r4 with transgo shift kit
Axle/Gears: ?? not sure yet just got the car
I hate lifters...
OK, i wanted to get some suggestions from people that would know more about this than me... I have a '90 305 that I just converted from tbi to carb with a 700 r4... an edelbrock 2701 performer intake and a edel 1406 carb... a lifter started tapping on me so I figured while i fix that, till I get my crate motor, I would go ahead and put a better cam in there with a new timing chain... I wanted to get some suggestions on a cam and lifter kit that would be decent for the money... nothing to amazing due to Im saving for a 383 in the future.. something that would wake it up but not break it... by the way I will be running the stock swirl port heads(yes I know they are crap) Just wanted to see what u guys thought... sorry for the long post
Old Apr 12, 2007 | 07:54 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: I hate lifters...
Well, i hate to say it but if your looking for a cheap and mild cam you can pick up an edelbrock cam & lifter kit for next to nothing.
But as usual, you get what you pay for. The cam uses a VERY old grind, thus isnt really a great choice for someone looking to make some good power.
Where are you located? I have a used edelbrock cam you can have for a few bucks plus shipping if you want.
Old Apr 13, 2007 | 06:46 AM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
well I would buy it but im not a big fan of edelbrock... only reason I have the intake and carb is because it was the right price lol i was looking into something from crane cams that came with lifters... i believe it was a 260 duration, .440 lift something or another cant remember the rest... but was a mild cam that wouldnt blow up my motor
Old Apr 13, 2007 | 11:48 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
yes, something like the 262 cams are enough to give a stock motor a little wakeup call without having to do much else to the car.
Old Apr 13, 2007 | 11:53 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
are you sure your lifter tapping is just that? It could be the valve seat leaking by. Do a leakdown test before you spend cash.
Old Apr 13, 2007 | 04:50 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
exhaust leaks also sound very similar to a lifter/rocker tapping....
Old Apr 13, 2007 | 06:33 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
look at the summit brand grinds.
Old Apr 13, 2007 | 11:12 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Get an lt1 cam. Havent used mine yet but i bought it off of ebay for 25$. Great shape.
Old Apr 14, 2007 | 07:16 AM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
Well i came to the conclusion that i Do have a lifter tapping and an exhaust leak... best of both worlds... so I ordered a new cam and lifter set... my valves are leaking badly judging from the smoke on start up so I found a good machine shop down here thats gonna get me some rebuilt 187 **** heads for cheap cheap, as well as a new timing chain... just trying to keep this thing running long enough to get my new motor in which will take awhile
Old Apr 14, 2007 | 07:53 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
doing a "valve job" or swapping heads on a high mile engine is usually a bad idea as you are increasing sealing power the new valves which might cause blow by with the old rings and make any gains from new heads mote
Old Apr 14, 2007 | 11:23 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
I second that. dont polish a turd!
Old Apr 14, 2007 | 01:29 PM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
I agree with you on not to polish a turd!! lol but when i bought this car 6 months ago I was told they had the motor out and did a rebuild but threw on the heads cam and lifter from the orginal... didnt even get the heads reworked so I'm hoping they did rebuild it... cuz the thing was in **** poor shape when I got it... guess we will find out soon...
sammy52401
Nov 11, 2015 07:20 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
david068513
Sep 18, 2015 10:36 AM
