Spark Plug Removal
Old Apr 14, 2007 | 11:47 AM
rsenn's Avatar
Car: 89 IROC Z28
Transmission: 700R
Spark Plug Removal
In the FAQ section I read about how to get spark plugs out.
I recently purchased a tool from Snap-On that made it very easy for me.
It slides down the spark plug with a hex opening like a socket and has an external hex that accepts a 5/8" wrench up around the porceline.
My Camero has headers and I found it easier to remove most of the plugs from the bottom. I imagine stock mainfolds would be about the same.
The part number is S9724RHS. you can get off the truck, and it's well worth the money spent.
Old Jun 23, 2007 | 05:55 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Re: Spark Plug Removal
Thanx, I was just looking for a tool like that, hopefully it'll help my situation.
Old Jun 23, 2007 | 06:01 PM
Morder.'s Avatar
Car: 20 M550i xDrive
Engine: LB9 305 TPI
I've found it to be a royal pain in the *** to do it from the top or bottom with my headers, I think its worth the money to let someone else do it unless you got an engine crane and you can lift your engine up a tad.
Old Jun 23, 2007 | 06:19 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
You can also buy a craftsman 1/2" drive spark plug socket, and cut it in half. Slide it over the plug and use a wrench to crack it loose. Cheap and very effective if you have headers.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
