tranny slipping when warm??
Old Apr 19, 2007 | 07:22 AM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
My car has 142K on it. The owner I bought it from said the trans has never been rebuilt. When i get in the car and let it run for a few minuts in the morning it shifts absolutly wonderfull and the car has a **** load of power, I can nail it and it will shift to second burning rubber leaving 40-50 foot marks.
But once it gets all the way to operating temp I can nail it from a stop and im lucky if it breaks the tires loose for more than 5 ft and the shifts get VERY VERY SLOOOOOW once it is warm.
Can this be corrected with a shift kit or am I looking at rebuild time?
Old Apr 19, 2007 | 08:09 AM
Vader's Avatar
Re: tranny slipping when warm??
Is there a particular range where the slippage is more evident? Does is still shift softly when manually shifted through the ranges?
Testing the line pressure when hot would be a good idea. Make sure the pressure in manual ranges rises about 90-100 PSI in manual 2 and 1. Also make sure the line pressue in PARK/OD/DRIVE increases to about 150 PSIG as the TV is pulled.
Depending upon your results, you may or may not be looking at some new parts.
Old Apr 19, 2007 | 10:39 AM
wannafbody's Avatar
Car: 88 GTA
is there a easy spot to check the pressure at? I have all the guadges at work just havent had the car in the air yet.
It shifts the same no matter if I manualy or automaticly shift it.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
mfp189
Sep 27, 2015 09:25 AM
