Porting heads???
Old Apr 19, 2007 | 02:02 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Porting heads???
plan to grab an lt1 cam headers better cold air intake and MAYBE aftermarket intake of some kind. i was reading on about DIY head porting. what would this do for me on my basically stock 89 camaro tbi 305 lo3??? and after i did the DIY porting and added my headers intake cold air and cam, what would i expect?
Old Apr 19, 2007 | 02:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Porting heads???
Don't waste your time porting the TBI heads.
Port other 305 heads, like the carb or TPI ones, but not those.
Old Apr 19, 2007 | 02:51 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
which heads would you reccomend that will just bolt right on to my lo3 and work perfectly? are there any heads non aftermarket out there that i could put on stock that will perform better? sorry to bother you with simple bs
Old Apr 19, 2007 | 03:13 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Look for the heads that came on Fbody TPI 305 motors.
The casting number ends in "081"
With full porting and larger 1.94" valves you can have a pretty decent performance head for low $$$'s
Recomend you drill and roll pin the rocker stud bosses.
MoJoe
Sep 24, 2015 09:12 PM
italiano67
Aug 31, 2015 06:04 PM
Brendankup
Aug 30, 2015 01:46 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
86White_T/A305
Aug 17, 2015 12:16 AM
