poly locks backing off?
Old Apr 20, 2007 | 07:26 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
I installed some 1.6rr's and this makes the second time the locks have lossened up, I cranked on them pretty damn good last time. Does anyone know how much your supposed to torque these to?
Old Apr 20, 2007 | 07:46 PM
Re: poly locks backing off?
Happens alot.
Especially to people that turn the nut to wherever they think it should be, and then think they're going to tighten the set screw tight enough to lock them in place.
The correct way to do those is to tighten them ALMOST to where you want them, maybe 1/16 - 1/8 turn loose; tighten the allen by itself; then go back, and with a box-end 5/8" and the allen, tighten the nut and the set screw TOGETHER.
Old Apr 20, 2007 | 07:54 PM
Damon's Avatar
Exactly what Sofa said. Do them that way and they'll never back off.
Old Apr 20, 2007 | 08:20 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
AMEN.. solid flat running 10 months so far with one valve "adjustment".. three other times just a feeler check..
BUT, i've only been about 800-1000 miles but you get the point
Old Apr 20, 2007 | 08:40 PM
wannafbody's Avatar
Car: 88 GTA
ahhh sweet, thanks alot guys I didnt want to tighten them to much but I guess that will work.
Old Apr 20, 2007 | 08:50 PM
5678TA's Avatar
Car: 1984 Trans Am
dont tighten it to the point you strip or snap the rocker stud.. obviously.. but if you are going at it, and theres more to turn, but the lock wont turn, back off and try again..
i promise you, you will cry when you snap a stud and dont have another stud and poly lock on hand.. its a horrible feeling of defeat.. lol
just use your good judgement
Old Apr 20, 2007 | 10:03 PM
wannafbody's Avatar
Car: 88 GTA
gotcha thanks
Old Apr 30, 2007 | 03:02 AM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
hey guys i seem to be having the same problem. We did the valve lash about 5 times today and still as soon as the engine gets running they just loosen themselves up really fast. SO i guess ill try doing them like that tomorrow. Lets just hope nothing broke when i was driving it when they loosened up....
Old Apr 30, 2007 | 03:24 AM
5678TA's Avatar
Car: 1984 Trans Am
when you say they loosen, do they actually get loose?? like you can turn them by hand(overexaggeration) or are they still tight and just tapping??
if they really get loose then its just a locking problem.. but if they are still tight and tapping, then you have problems..
Old Apr 30, 2007 | 04:21 PM
F-Bobby's Avatar
yeah figured out that this is rthe last tiem i listen to anyone else when it comes to my own ****ing car. when they did the lash they set it at TDC #1 then only rotated the crank half a revolution not 1 full revolution so the cylinders we were doing were in mid stroke when we tightend them. i was busy doing other **** so i didnt notice. now i know.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
NBrehm
Aug 5, 2015 07:57 PM
