Rebuilt engine-no start-need help!!!!
Old Apr 21, 2007 | 09:02 AM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
Replaced tired 305 tbi with rebuilt 350 tpi. New wiring harness with all connectors labeled, new holly fuel pump. Engine cranks, fuel pump not running. jumper to the fuel pump and pump runs. Crank engine again, I get spark but no fuel, I give it a shot of starting fluid and it fires and runs until the starting fluid is gone. checked the pump fuse, and relay, they're ok. seems to be a fuel problem. injectors don't seem to be working along with the fuel pump. ANY SUGGESTIONS?????
Old Apr 21, 2007 | 01:52 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Rebuilt engine-no start-need help!!!!
what year 350 tpi setup did you install
what about VATS
do you have pulse to the injectors
whats the number on the computer
Old Apr 21, 2007 | 08:32 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
it's an 89. found out the ecm wasn't getting power so we hooked up a power feed from the battery. everything worked then, including the fuel pump. idle is too high, and the fans didn't cool enough. had to wire the fans to come on as soon as the key was on to cool the engine. that seemed to work. now the temp is way below 220. also had to get a new oil sender/switch because it wasn't sending a signal to turn on the fuel pump. other than the idle being too high (about 1200-1400), everything seems to be ok, no ses light either!!! any suggestions on lowering the idle?
Old Apr 22, 2007 | 10:37 AM
jamon8's Avatar
Engine: 350 tpi
you have to set the IAC
http://sethirdgen.org/trd.htm
try this website
its under set minimum air
Old May 1, 2007 | 11:00 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
all my problems seem to have been caused by a bad maf sensor. swapped that out and everything seems to be working now.
Old May 2, 2007 | 01:22 PM
jamon8's Avatar
Engine: 350 tpi
I am glad everything worked out for you
the mafs can cause all kinds of problems
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mrbird
Oct 20, 2015 03:43 AM
KO1
16
Oct 15, 2015 05:00 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
