Do I Need small base circle cam?
Old Apr 22, 2007 | 12:13 PM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
im lookin for sumthing in the range of 256/260 .627/.622 solid/roller on a 110 lsa... SOLID ROLLER... the cam i have now is a 530/550 234/242 on a 112 lsa.. and my rods are really close to the lobes.. im afraid that if i go to a higher lift and stuff my cam will smack my rods what do u guys think i should do??
oh yeah the motor is carbed now with a 1050 quick fuel on top...
Old Apr 22, 2007 | 03:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Do I Need small base circle cam?
The lobes won't get any bigger, they can't be bigger than the journals otherwise you wouldn't be able to get it into the engine.
I think you'll be fine.
You might want to get slightly longer pushrods though, but when you get the cam you can check it.
Old Apr 22, 2007 | 05:34 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
The way they increase lift is by taking material off of the low side of the lobe not increasing the high side.
Messing around as a kid we used to file down gocart cams. It would be a dog off of the line but that thing would scream up top.
Old Apr 22, 2007 | 11:54 PM
91_B4C_RS's Avatar
thanks guys i kinda feel like a dumbass but atleast i learned sumthin
Old Apr 22, 2007 | 11:58 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
what they said.. but dont feel bad cause you have to start somewhere.. took me a bit to figure that part out..
at most, you might need a bit longer pushrods.. since the lifter will sit lower..
junkcltr
Aug 2, 2019 11:12 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
