eagle cast steel 400 sbc crank
Old Apr 23, 2007 | 02:25 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
hey guys i was just wondering how much hp/torque/rpm cane a eagle cast steel 400 sbc take before breaking. just a estimated guess because i have a guy that will sell me a 400 block cheap but it doesnt have a crank. thanxs
Old Apr 23, 2007 | 07:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: eagle cast steel 400 sbc crank
I think those are rated at around 500HP, or around 6000RPM or something of that nature. It's a mid of the line piece IIRC.
Old Apr 23, 2007 | 08:11 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Sonix is right. I have seen people pushing 600 with there 383 (same crank diffrent journal size). Eagle rates them at 500, they will take more but you never know how much and dont want to trash the rest of the motor finding out.
Old Apr 23, 2007 | 10:29 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
awesome thats about the numbers i was hoping for, about 500hp would be just about as much as i would need. although they say too much horsepower is almost enough. thanxs guys
Old Apr 23, 2007 | 10:40 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I would worry more about the stock block splitting in two. Seems the way they always end up when extremes are pushed.
Old Apr 23, 2007 | 11:33 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
so you are saying i should get an aftermarket 400 sbc block to get 500hp?
Old Apr 23, 2007 | 11:42 PM
shaggy56's Avatar
Car: 71 Nova
Not a bad idea but you should be fine if you use quality fasteners on the mains. Im just saying the block will most likely go before the crank.
Old Apr 24, 2007 | 12:08 PM
mightymouse383's Avatar
Car: 91 camaro
Engine: 383
Transmission: th350
Axle/Gears: 4:10
I would invest in some good rods to handle that amount of power, i think the stock block would be fine if its preped right and definitley use good fasteners. you should be fine.
Old Apr 24, 2007 | 11:35 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
thanxs guys for the help and yes i plan to use good internals just a stock block so i was just a little worried about the crank. nothing is set in stone yet about the 400 so we shall see what happens.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
