Answer needed fast, will my power steering pump burn up running it dry?
Old Apr 27, 2007 | 05:36 PM
85xtransxam's Avatar
Car: 1985 trans am
Engine: 305 tpi 5.0L
My power steering just pissed out all of the fluid and now i spend just as much on power steering fluid as gas but i still have to go to work. Q: will my power steering pump burn up if theres very very little fluid in it? like im talking maybe a couple of oz. in it, but i might be over exadurating tho.
Old Apr 27, 2007 | 05:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Answer needed fast, will my power steering pump burn up running it dry?
If it was the power steering pump that leaked all the fluid, then it already needs to be replaced.
Old Apr 27, 2007 | 06:35 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
If your pump leaks the fluid. You could screw up your gear box. No fluid means steering gear box goes bad. Ask me how I know. fluid also serves as a lubricant.
Old Apr 27, 2007 | 07:43 PM
jjb's Avatar
jjb
Car: 1986 Z28
Just like any of the other systems in your car which require oil as a lubricant, if there is no oil in it, some type of damage will be the result. Granted, I have fixed cars where they had been running the power steering pump until it was dry and then adding oil for months until they brought it in for repair, fixed the leak, and no problems. I have also had them run dry a single time and the pump made noise after the leak was repaired.
So the real question is, are you a gambling man?
Old Apr 28, 2007 | 03:13 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Might as well If you have to get to work..
Apeiron already stated that its possibly bad to begin with.
What do you have to lose? Besides your job, that is..
Old Apr 28, 2007 | 06:08 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I had one spring a leak in a cooling line before (different car). Wow did that thing squeal after the fluid dropped too low. Apparently I lost that gamble. I had to replace the pump.
Old Apr 29, 2007 | 09:20 PM
Car: 1985 trans am
Well thanks on the info.
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
theshackle
Mar 5, 2017 06:37 PM
IROCZ1989
Jan 24, 2016 03:55 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
