Which spark plug gap?
Old Apr 28, 2007 | 09:57 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I'm putting NGK TR55's in my 89 camaro, im wondering what gap I should go with. I have a 305 w/ dart al heads, msd digital 6, msd blaster coil, stock dist w/ accel cap and rotor (msd dist needs to be fixed), kn airfilter, msd 8.5mm super wires, etc. I've been searching and i've seen that stock is .035, but I could go to .045 b/c of the msd? Is that a good idea? What gap should I use? I may just compromise and go 40 or 42, i dunno whada you guys think?
Old Apr 28, 2007 | 10:38 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Re: Which spark plug gap?
most efi cars I would use .045 more often then not.
Old Apr 29, 2007 | 08:47 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
With stock compression and the MSD setup it should have no problem at all with .045" .
Old Apr 29, 2007 | 08:53 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
I have performance pistons in there I think the compression is a little higher since I have to use half premium half regular, does that make a difference? Is .045 ok? Should I do .040? I only want to do this once
Old Apr 29, 2007 | 09:50 AM
Engine: 350 4BBL
.040 should be on the safe side for higher than normal compression with the MSD setup. The only difference between .045 and .035 is a minor difference in emissions when the engine is cold. No real difference in performance compared to the difference between stock ignition and the MSD.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
Jlanz55
Sep 6, 2015 03:05 PM
