Ignition Control Module
Old Apr 29, 2007 | 08:53 AM
mrrilla's Avatar
Car: 1939 Chevy Coupe
Engine: 383 TPI, Dart Pro1 180cc heads, etc
I am having a problem with the ignition control module in my 87 HEI (Big Cap) Distributor. I have repeatedly changed the modules in order to get my noid light to blink. I have even swapped out the pickup coil once. The ICM is always installed with dielectric grease and the connections are tight.
My question, what can cause the ICM to blow? I think its getting some voltage spike or feedback but I don't know where. Can the coil cause it? bad grounds? spark plug gap? pickup coil? ECM mapping?
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
