bad miss..power loss
Old Apr 29, 2007 | 11:37 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I have been having a bad miss since I took my car out after sitting for the winter. Rough Ideal, power loss,stalling..ect. I have changed the plugs, wires, cap, and rotor. I have also checked my timing and fuel pressure. Still having the same problem? I plan on changing my ign coil which could be the possible problem, I have just noticed it arching from the terminal on the MSD Blaster coil. The arch travels from the termial under the coil wire boot and tracks about1 1 1/4" until it finds a ground. Really strange, has anyone ever seen that happen before??? Hope replacing that is my fix, if not I will do a compression test on all my cylinders.. Any advice would be great..thanks
Old Apr 29, 2007 | 01:48 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: bad miss..power loss
Sounds like one of the piston rings are stuck.
Old Apr 29, 2007 | 03:21 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I am having the same exact problem man and I have changed all of what you have and more. The only thing I can think to do now is change the 02 sensor and test the injectors.
Old Apr 29, 2007 | 03:45 PM
Car: 89 Formula 350
I'm leaning towards my problem being a bad ignition coil....
wigmobile
Feb 26, 2025 02:56 PM
MM2Robinson
Oct 1, 2017 09:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
SG91camaro
Sep 5, 2015 10:27 PM
RyanJB
Sep 2, 2015 01:27 PM
