Question about rear main?
Old Apr 29, 2007 | 03:44 PM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
I have an 88 formula 305 tpi. Is it a one or two piece rear main, I heard that it is a one piece rear main since it was built after 86? The reason I need to know is because I want to know if my flywheel will work for the t56 swap.
Old Apr 29, 2007 | 03:53 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: Question about rear main?
You are correct it is a 1piece RMS.
Old Apr 29, 2007 | 04:02 PM
Engine: 305 tpi lb9
Axle/Gears: 3.45
I have an 05 viper t56, will an lt1 clutch bolt to that flywheel if i get the right bellhousing for the t56?
Old Apr 29, 2007 | 07:44 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
you mean a T-56 from a dodge viper?
or the aftermarket GM/viper T56. i am prettysure it will
Accepts stock GM clutches,linkage,T.O.B.,pilot bearing,trans. mount
Old Apr 29, 2007 | 07:51 PM
Engine: 305 tpi lb9
Axle/Gears: 3.45
The transmission is from an srt-10 ram, someone had it replaced under warranty and they didn't want it back so I offered to take it. I need the gm bellhousing that uses a hydrualic throwout bearing not sure if it will work with the input shaft tho.
Old Apr 29, 2007 | 07:56 PM
Car: 91 RS
Engine: 350 vortec
count the the teeth on the shaft it should be 26 i think and be 1.125 wide i think
Old Apr 29, 2007 | 08:03 PM
Engine: 305 tpi lb9
Axle/Gears: 3.45
yeah it is a 26 spline, i don't have the t-5 out but the pilot bearing for that is alot smaller, i think i have to swap the shaft from the gm t-56 that has the smaller tip for the pilot bearing.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
