got the shakes :P
Old Apr 30, 2007 | 08:44 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
got the shakes :P
ok when sitting about 100KMph or 62Mph i get a bad vibration through the flore, it has only just started in the last fue weeks (i get the Express way every morning on the way to work and on the way home so i hit this speed fairly often).
I don't evan know if this post it is ment to go here i just need to get this sorted ASAP, any help would be greatly appresiated.
Old Apr 30, 2007 | 09:07 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: got the shakes :P
Check exhaust components for clearance to the floor pan and the frame. Also check the front and rear universal joints on the driveshaft, torque arm mount to transmission, rear crossmember and trans mount bolts.
Old Apr 30, 2007 | 11:24 PM
VenomX-87's Avatar
I know that I have 1 shot engine mount (RHS under my steering colum, complete PITA to get to) and a bum gearbox mount coz if i plant my foot my gearbox hits the flore (I know there is no point in doing the gearbox mount till I have the time to fix the engine mount coz it will just brake again).
But they have been stuffed for ages so i doubt that they are causing this new problem.
I will look over the uni joints and torque arm mounts when i get a chance.
Old May 1, 2007 | 12:09 AM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Your lack of tranny mounts may have wore out your u-joints from all the moving around.
Old May 1, 2007 | 12:16 AM
VenomX-87's Avatar
nub question but where r the u-joints?
Old May 1, 2007 | 05:07 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
driveshaft
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
xxx3man`
Sep 23, 2015 10:37 PM
88rscamar0
Sep 23, 2015 09:08 PM
Amillionoh7
Sep 5, 2015 11:44 PM
