thinking about a 383, need answers
Old May 1, 2007 | 08:46 PM
sc02t's Avatar
Car: '05 Trailblazer, '97 Z28
i just found out that i am starting to burn oil. i was thinking that while i was working on it, i would maybe stroke it. i found a site that sells a budjet 383 stroker kit http://www.speedomotive.com/ps-41-8-...crank-kit.aspx . besides this, what else do i HAVE to have. i don't have a lot of $. can i keep the factory tpi? computer? cam? i have searched but i did not find any answers.
scott
Old May 2, 2007 | 12:55 PM
sc02t's Avatar
Re: thinking about a 383, need answers
come on guys! i know somebody out there knows this!
Old May 2, 2007 | 01:17 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
you'll need to clearance the block.
Old May 3, 2007 | 03:55 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
a computer is a computer, it dosen't know anything except what it's told.....
it will expect to be operating a tpi 350 with factory programming, if you mod it then you will have to have the programming changed so that the computer can be in the ballpark to compensate, massive tuning for highly modded engines...
your machine shop should be able to clearnce the block and do what you need done, just make sure you tell them everything you plan on so they can prepare the block for it.. communication is key!
Old May 3, 2007 | 06:07 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Yeah, either re-program to meet your specifications
OR
Ditch the ecm and go carb. A decent Holley atop an Edelbrock RPM Air Gap.
Old May 3, 2007 | 07:35 AM
sc02t's Avatar
i want to keep the tpi or something simalar. i thought that your could buy a crank that was ready to just drop in to a 350 with no clearance issues. anybody you could recomend for the comp modding?
Old May 3, 2007 | 10:13 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Yes, you can buy a new Scat crank to just drop in there however, the longer stroke will require clearancing the block for the rod bolts. The block rails where the oil pan bolts to and possibly the bottom of the cylinders. If you have a die grinder you can do it yourself and save some cash but it will require several trips to and from your machine shop.
Have you looked into the Holley Stealth Ram for a decently priced and appropriate intake mod? The TPI will be further restricted as your new displacement tries to pull more air in, it's just not efficient for a 383, 305 yes. You'll definately need larger injectors too, depending on your cam selection and heads you may be able to get away with 24#'s but 30's for a nasty street car with a decently modded engine.
Can you tune? You'll definately need the knowledge to tune, dont trust an off the shelf chip, it's a joke.
midge54
Jan 29, 2017 07:00 PM
Thornburg
Aug 25, 2015 01:46 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
