Need a new alternator which one to buy?
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I am ready to get my car on the road but I need a new alternator. I have a 355 and a 50,000 volt coil if that matters. How high of an amp should I go for a new alternator ??
Car: 1984 z28
Engine: 355
Re: Need a new alternator which one to buy?
Well I just looked up the stock replacement and the vary from 63,78,94,100 or something to that effect. So again which to buy ?
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
When my '83 needed a new alternator I went with a 105 amp.She has all power options(windows,locks,driver's seat and antenna)and I have gone to the factory dual fan setup.I looked up the what would be compatible(single groove pulley-which can be swapped and mounting position).You also go with the newer 140 amp models with some modification.The price difference on the ones I looked at was very little so it made since to upgrade.
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
what modifications are necessary to wore up one of the 88 alt. style to me existing 83 ven (I'm swapping in a serp. setup from a 88 z)
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Power wipers and high beams draw some decent current. I had a 37A on it when I picked up my car, ran fine though.... If you don't have a stereo, pick up what ever is in stock, it won't matter much.
I swapped to a 140A version of the CS144. Look up my thread, it's pretty detailed. It shows how to swap to that, it's easier on the V-belt cars, less modifications than on a serp car. And $50 from the wreckers for 140A? Yep, good deal for me.
Car: 1984 z28
Engine: 355
All I have really is a aftermaket cd player in the car I was just worried about the higher output coil I have on my car. I want to have strong spark. I guess I will go with the 78amp and call it a day.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
