Switching Cams...
Old May 5, 2007 | 11:13 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Switching Cams...
I've done a search, and couldn't find this, so my apologies if it's been asked...
But is it possible to remove and install cams without removing the engine from a Trans Am? Like..if I took out the radiator and the A/C condenser, would it be possible to maneuver the old cam out of the block and the new one in? Has anyone done it?
Old May 5, 2007 | 11:17 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Re: Switching Cams...
yep, you have to take most of the front apart(radiator, condenser, various braces). i don't remember if you have to pull the bumper cover though.
Old May 5, 2007 | 11:20 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Man, that would suck if I need to pull the bumper cover. But it'll work better than trying to remove an engine without a cherry picker or an engine stand. But then again, I'm just planning for the future, so I'm in no rush, and who knows, maybe I'll somehow 'acquire' a picker and a stand by then
Old May 6, 2007 | 12:02 AM
kenf729's Avatar
Car: 1989 Camaro RS, 355, holley 650dp
Engine: flow master headers, 3" exhaust
Axle/Gears: stock
Done it in a Camaro, just had to remove the AC and rad...and unbolt the braces, was an easy few hours....don't think the engine bays are that much different.
Old May 6, 2007 | 02:14 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
http://home.comcast.net/~stekman/Cam_swap.doc
Give that a read.
Old May 6, 2007 | 07:16 AM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
