350 in 85 z28
Old May 9, 2007 | 07:49 PM
vinflamesv's Avatar
350 in 85 z28
Me and my brother recently took up taking out the 305 that was in my camaro and dropping in a 350 out of an old '74 c10, and we've been working on it for about 5 months and it's just about ready to drive.
From what I can remember my brother redid all the oil seals and checked the bearings and everything seemed to be fine on the engine.
We cleaned the engine bay up a little bit, got everything working right on it (except the gauges) and we hear a knock... The car also has some pretty bad vibrations going on on the passengers side. A friend of mine told me to check the torque converter and one of the bolts was really loose so we tightened it back down, and after that it still knocked. So the guy said it could be a rod knocking. Me or my brother don't know a whole lot about mechanic work and we're pretty much at a loss here because we don't know what else to do. Has anybody ever run into this kind of problem before?
Old May 9, 2007 | 07:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 in 85 z28
What kind of a knock is it?
Old May 9, 2007 | 07:54 PM
vinflamesv's Avatar
Re: 350 in 85 z28
it sounds like something knocking (a constant tick tick tick tick) and I can only really hear it from under the car... I'm guessing it could be a warped flywheel, bad torque converter, headers knocking on the frame, exhaust leak, or the rod knocking like my friend suggested, and we just really don't know how to check.
Old May 9, 2007 | 08:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 in 85 z28
See if you can find a mechanic's stethoscope to locate the sound, or you can even just improvise with a piece of tubing held up to your ear.
Old May 10, 2007 | 01:44 PM
vinflamesv's Avatar
Re: 350 in 85 z28
took it to a mechanic and they said my motor mounts are shot, and i need to get something else done to my exhaust too
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Linson
Aug 31, 2015 04:52 PM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
