Steering Wheel Alignment
Old May 9, 2007 | 08:49 PM
bm2xv's Avatar
Hey, I recently got in accident with my 92 camaro rs and the steering column got bent along with the rest of the front end. I recently had a body shop straighten everything and it's all back to normal, except the steering wheel is slightly tilted to the right, making it hard to see the gauges while driving. The actual steering is fine it's just the steering wheel is tilted. So I was wondering if there was any way i could just center the steering wheel back?
thanks,
brandon
Old May 12, 2007 | 11:23 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Re: Steering Wheel Alignment
A body shop is exactly what it says, a body shop. Screw them, don't take it back but instead, take it to an alignment shop (tire store with electronic or computorized alignment rack) and tell them your problem. They will first, straighten your steering wheel and then set your alignment to the position of the steering wheel. I had the same problem after replacing the tie-rod ends.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
