Can't find a set of injectors!!
Old May 9, 2007 | 10:03 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
I cant find a set of new fuel injectors under $300 for nothing...
I need a set of 22 lb injectors badly, and all I can find are 21, 23, 24, and everything else, but not what I need....
I need a link to some kind of aftermarket injectors, im about to go crazy.
I would just go to 24 lb injectors, but I dont have the money to have the chip re-tuned.
Old May 10, 2007 | 02:13 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Can't find a set of injectors!!
21lbs are just 22lbs injectors at a lower pressure reading. They'll work fine. 23lbs are either 22lbs at a higher pressure, or 24lbs at a lower pressure. Get the 21lbs and you wont have to reburn the chip.
Old May 10, 2007 | 09:19 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Even with a modified engine?
Old May 10, 2007 | 09:06 PM
Kevin91Z's Avatar
Define modified. A custom chip will benefit any engine that is changed from stock. But the factory tune can usually handle bolt-ons. Its a camshaft and head swap or larger injectors that will give you trouble.
Old May 10, 2007 | 09:09 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
MSD Ignition
Edelbrock Headers
Bored .30 Over
Comp Cams .500/.510 Lift Camshaft
Ported, And Polished Heads
Ported Intake Manifold
Flat Top Pistons
Custom Burned PROM
ACCEL 8.8 Wires
Custom Porting To TPI Plenum
K&N Air Filter
The engine only has about 2800 miles on it, it had a complete tear-down and rebuild just under a year ago. About the only thing original is the block....and the injectors
There has been a couple other things done to up power, but those are the actual "mods" to the engine
Old May 12, 2007 | 11:33 PM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
i have a set of used injectors, 22lbs that i had in my car for a while and had no problems with them. dont know if your interested in used or not but if so pm me for more details
Old May 13, 2007 | 01:11 AM
Kevin91Z's Avatar
Who did the custom prom?
Do you have an adjustabe fuel pressure regulator? As I said, you can use the 21lbs with the pressure at 42-46lbs, or the 23lbs with the pressure at 38-42lbs.
specialized
Jun 18, 2022 09:26 AM
Steve78LT
Feb 24, 2016 12:15 AM
twest2k2
Aug 24, 2015 11:26 AM
justin57
Aug 20, 2015 07:05 PM
Firechicken86
Aug 12, 2015 10:07 PM
