O2 sensor on LG4?
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
O2 sensor on LG4?
Hi,
I have a TA-85 with the LG4 engine. Does it have an O2 sensor? If so, what does it do? Does it control air/fuel mix on a carburated engine? I also wonder what the ECM does for my car?
Hasse
Hasse
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: O2 sensor on LG4?
The O2 sensor should be on the driver's side exhaust manifold, if equipped with a computer controlled q-jet. For some discussion of the carb and system try:
https://www.thirdgen.org/forums/carb...-one-year.html
https://www.thirdgen.org/forums/carb...a-305-lg4.html
https://www.thirdgen.org/forums/carb...qjet-need.html
https://www.thirdgen.org/forums/carb...e-rebuild.html
Note that many export models were not computer-controlled; only domestic ones.
The ECM controls the ignition timing and the fuel mixture; a few emissions-related components; and the torque converter lockup clutch, in automatic cars.
HoosierinWA
Oct 7, 2015 10:15 AM
