new heads????
Old May 11, 2007 | 09:02 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
new heads????
ok guys, like some of you might know, i'm getting a little engine oil im my radiator, i talked to a mechanic about it and he said that i need to get new head gaskets, and he started telling me that he needed to send the heads to the machine shop to corect and get a valve job done to them and all this was going to cost me $2,000. so then i thought that maybe it would be faster and cheaper to get new ones and if so, i wanted to ask you guys if i could get some 350 or like 305 vortec heads that could bolt right up out of the box, and can i find these at a chevy dealer? please help, this is my first V8thanks
Old May 11, 2007 | 09:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: new heads????
It's really hard to give you advice without knowing anything about your car eh?
That's what the personal info side bar is for. So we know what year car, what engine, etc etc.
Yea, the labor is what makes up most of that bill, it takes many hours to tear down to the heads and pull them, and at $100hr, that's it.
Vortec heads won't bolt up to your engine without a new intake manifold, and maybe other things as well, again, goes right back to what engine do you have, what year car, etc.
You can always get some entry level aftermarket heads that'd bolt right up, but you're still going to have to pay labor to have them tear it down and take off the heads, and put on the new heads. Shaving your heads only costs ~$60, out of the $2000. So if you get $700 heads instead of the $60 milling.... Well, you get the idea, it'd still run you $2500 or so.
Unless you don't mind getting your hands dirty and doing it yourself. Do you have a garage to do the work in?
Old May 11, 2007 | 09:48 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Re: new heads????
ok, the car is a 86 camaro Z28 LB9 305 TPI
Old May 11, 2007 | 10:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: new heads????
'86, TPI 305? That stock? I thought that motor combo was extremely rare...? Maybe that's the 350 in '86.
Yea, you could get SR torquers or something, but that's barely an upgrade, for the price. You could port the stock heads, but if you aren't inclined to even remove them yourself, then it's probably not a job for you.
Old May 11, 2007 | 10:31 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Re: new heads????
yeah, thats the stock motor set up i have, and it is a 305 .
Old May 11, 2007 | 11:07 PM
BigDreams92's Avatar
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
Re: new heads????
It should have "416"casting heads on it and you can have those worked pretty good. There's a thread some-where on here on how to do a pocket port to them.
$2000 to have some-one do gaskets and valve seals to my car would make me cringe, sounds like an excuse to learn more about your V8 and save some of that money.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
