Diffrent AFR LH/RH
Old May 13, 2007 | 03:11 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Diffrent AFR LH/RH
This is tearing me down....I need some useful hints!
I get diffent AFR between LH/RH cyl.banks under acceleration
- Swapped injector drivers
- Swapped side of the injectors
- Checked for vacuum leaks
- Checked for exhaust leaks
- Relocated both WBO2 bung at the same distance from cyl.head.
- Swapped side of the WBO2 units/sensorn
- Disconnected all the other inputs from TPS/MAP... to eliminate elec.fault.
- Grounded all the WBO2 eq at the same place
-> Still no change
Se picture from scan
Could a vacuum leak between intake/head to the lifter valley cause this?
Why is it diffrent when I accelerate and not else?
Purple- RH AFR
Yellow- LH AFR
Red- MAP
Green- TPS
Black - RPM
Attached Thumbnails Diffrent AFR LH/RH-capture_05132007_220330.jpg
Old May 14, 2007 | 08:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Diffrent AFR LH/RH
Just watching.
Old May 14, 2007 | 09:33 AM
Sierra GT's Avatar
Car: 95 Sierra GT 4x4
Transmission: 4L60-E
Axle/Gears: Stock 10-bolt w/ 3.42's
Try swapping the injector wiring harnesses. Maybe it's possible that one side has more resistance than the other?
Other than that, I haven't a clue. Your car hates you. lol.
Oops, just figured out you're not running TBI. Has the car always done this?
Old May 14, 2007 | 11:41 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Probably have a misfire. You're getting o2 from somewhere, and it's hard to detect a fully misfiring cylinder if you've got a big shaky engine. Could be a bad plug that jumps a crack during load. Could be a plug wire. Could be distributor cap. Could be THAT cylinder head is not grounded well (ground both).
Old May 14, 2007 | 12:15 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I swapped the harness (drivers) with no result.
Oh, I forgott the first thing I did
- New Plugs and new wires MSD 8.5 mm, gap set to 0.9mm
Did a compression test today, ( had to remove the headers)
8.5-9.0 on all...........
Its not that shaky and it feels smooth and the log (AFR) is stable so I dont think its a missfire..........
Search goes on.............. will put an xtra ground to RH cyl head.
Time to mount back the headers and adjust the valves and try some other things. Keep you updated and let all me know all ideas!
Old May 15, 2007 | 01:50 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Suspect burnt valves, will remove the heads and have a look
Old Jun 7, 2007 | 03:07 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
found 3 burnt ex.valves.
Had them fixed and put it together and still the same reuslt
I need more ideas!
ULTM8Z
Oct 2, 2015 01:25 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
tuningnewb
Sep 23, 2015 07:06 PM
355tpipickup
Sep 13, 2015 11:35 PM
