3 wire heated O2 sensor wiring???
Old May 15, 2007 | 12:15 AM
TPI84GMC's Avatar
I am adding a heated O2 sensor to my car and am curious how to wire it. 3 pin connector. a and b are both white wires c is a black wire. how should they be properly hooked up?
Old May 15, 2007 | 01:00 AM
91chevz71's Avatar
Re: 3 wire heated O2 sensor wiring???
Black- data to old O2 wire
white-12v switched (ignition or something else)
white-ground
-doesn't matter on the whites, just make sure one is switched 12v pos and one is ground.
Old May 15, 2007 | 01:03 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oh, I remember having to look it up when I threw one in mine, and it had the same ambiguous wiring with it...
Right, so the 2 white wires are power and ground for the heater coil. The black wire is what you'd measure.
So usually you'd hook up a switched power source to a white wire, the other white wire would go to a ground source nearby, and also to the negative on your gauge or multimeter, and the black would be the positive on the gauge or multimeter.
Old Jun 11, 2007 | 06:59 AM
Ryan3834me's Avatar
Car: 88 TA
Engine: 383
Axle/Gears: 2.77
I am electing to go 3-wire sensor myself.
I guess I dont understnad why they didn't just go with 2 wires instead of 3, since the body of the sensor is a ground to the manifold. (and a big ground at that). I would think big enough so as not to interfere with the readings of the sensor element itself. anyhoo...
Anyone know what the amp draw on the heater element is. I am contemplating where to splice in for the switch 12V source.
Old Jan 2, 2008 | 08:35 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
stumbled on this today. this is link is to an O2 sensor maker's catalog in Brasil and they list an O2 sensor as needing a 7.5 amp fuse http://www.thomson-net.com.br/arquiv...sor_Lambda.pdf
it'd be cool to have this from Bosch but this is as close as I found: Some of the other interesting facts from their catalog:
- FREQUENCY
100 ms @ 350°C (662°F) – 50 ms @ 800°C (1472°F)
- INITIAL WORKING TEMPERATURE
300
°C (572°F) without internal heating
150
°C (302°F) with internal heating
- INPUT VOLTAGE OF THE HEATER
12 to 14 volts
- OHMIC VALUE OF THE HEATER
2 to 4 ohms
- HEATER FUSE
7.5 amperes
- THREAD
M18 x 1.5
- HEXAGONAL
22 mm
- TORQUE
40 … 60 Nm
MAXIMUM WORKING TEMPERATURE 1000°C (1832°F)
- 03 Wires -
Output signal (black wire), two wires to power the heater (white wires) and the negative is made by the Sensor thread attached to the exhaust system.
- Ideal air/fuel ratio:
• Gasoline – 14.7:1
(14.7 parts of air for 01 part of gasoline)
• Alcohol – 9.0:1
(9.0 parts of air for 01 part of alcohol)
• Diesel – 15.2:1
(15.2 parts of air for 01 parts of diesel)
Old Jan 3, 2008 | 12:25 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Typical heater draws about 4 - 6 Amp when cold and drops once NBO is up to operating temperature. The reason for three wires is that exhaust system is notoriously resistive - due to corrosion, bad ground return. You can improve over three wire (AFS-74) by going to four wire NBO (AFS-75). In four wire system extra wire is used to provide return path for signal wire back to ECM. However, some calibrations take into account extra ground losses by lowering stoich voltage from 450mv down. This can be easily changed in EPROM.
//RF
Old Jan 3, 2008 | 12:46 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Life could be a little easier if you wire a 3-wire weather pack plug to your engine harness in place of the single wire plug. Wire it in, then plug your sensor into it.
http://www.partsamerica.com/productd...goryCode=4074E
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Bert87
Aug 23, 2015 03:50 PM
fonzie85
Aug 13, 2015 11:50 AM
