Bad Fuel Pump?
Old May 15, 2007 | 02:16 PM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
Bad Fuel Pump?
About a month ago my fuel pump went and i put in a a/c delco. Car was fine untill a couple of days ago and it would not start. I tried a couple of hours later and it started up and ran for like 10 seconds and then stalled. After that it would not start. Tried again the next day and same thing. after it stalls and i try to start it and it just cranks there doesn't seem to be any gas smell. Think it could be a bad pump. Any ideas.
Old May 15, 2007 | 02:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Bad Fuel Pump?
Check the fuel pressure.
Old May 15, 2007 | 05:28 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: Bad Fuel Pump?
check fuel pressure. If none, check to see if you have power/ground to the pump.
Old May 21, 2007 | 03:54 PM
Car: 1990 trans am
Engine: 350 tpi
Re: Bad Fuel Pump?
O.K. i got the car to run. Whats weird is that i thought that what the heck maybe when i changed the fuel pump i messed up the float for the gas gauge. so i put in three gallens of gas. And it ran fine. Go to gas station to top it off and it only took five more gallons. Now the car runs just fine. Any insight in to what i might of done when i changed the pump. Thanks
Old May 22, 2007 | 10:05 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Bad Fuel Pump?
Maybe you messed up the float. Just keep an eye on your gas gauge if you're questioning it's accuracy. If you know your mileage per tank also helps. A spare gas can may be in order if you don't know your tank mileage.
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
