Knock sensor install for brand new engine?
Old May 16, 2007 | 12:28 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I had a 350 built with all new components including the block. I want to install a knock sensor to optimize timing & control detonation w/ the Holley commander ecu. The car originally didn't have a knock sensor, so I assumed I could just buy one and the module and hook it up to the computer. I called Holley and they claimed it wouldn't work since you need to know where to set the reverberation for the sensor. I probably won't be able to hear the detonation either, b/c I have a straight-thru exhaust after the turbo which is a little loud. Is there anything I can do to make it work?
Old May 16, 2007 | 12:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Knock sensor install for brand new engine?
You should be able to just install a 350 knock sensor.
Old May 16, 2007 | 07:18 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Autozone has the sensor & module for an '85 TA. So just connect everything up to the ecu and I should be good to go?
Old May 16, 2007 | 07:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I would think so, but I don't know why Holley would have told you that it couldn't be done.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
