What happens when you turn the key?
Old May 17, 2007 | 04:29 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
OK, i think i have a basic understanding of how most things work (car wise) except for this.. When you turn the key to start the engine, i know the starter cranks, the fuel pump runs, the injectors open, the spark plugs spark.. etc etc.. we have life!
BUT....
What happens when you turn the key off and you want to shut down the engine? It can't just turn off the fuel pump, the car shuts down too quick for it to of run out of fuel.. it can't turn off the injectors, carbs dont have injectors..
So, the question is, what ACTUALLY happens when you turn the key to off, how does it kill the motor? EFI, Carb, Diesel (i'm guessing Diesel and EFI will prob be roughly the same?)
Old May 17, 2007 | 04:35 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: What happens when you turn the key?
well, as far i know, it just stops sending electricity to the coil, but i could be wrong.
Diesel, I wonder if they just shut down the injectors.
Im not totally sure though.
Old May 17, 2007 | 04:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
On a gas engine, the power is turned off to the ignition. On fuel injected cars, the ECM, fuel pump and injectors also all lose their power.
Old May 17, 2007 | 05:09 PM
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
So one of the relays activated by the ignition switch supplies power to the Coil?
Cheers,
Richard.
Old May 17, 2007 | 06:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I believe coil power is switched directly through the ignition switch, not through a relay.
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
Kaweh
Aug 9, 2015 02:54 PM
