Not getting gas to fuel pump
Old May 17, 2007 | 08:11 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
i aint getting gas to the fuel pump i check the fuel pump its pumping good and replace the inline filter what else could it be?
Old May 17, 2007 | 08:56 PM
intex1982's Avatar
Re: Not getting gas to fuel pump
fuel pump under the hood and if the car had a fuel pump in the tank will it pump threw that i dont know much about the car bc it didnt have motor when i got it
Old May 17, 2007 | 09:21 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
sometimes you can pull fuel through an in tank pump, sometimes you can't.
there is no way to know for certain until you try.
the pickup screen in the tank could be clogged up.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
