Mass Airflow Sensor
Old May 20, 2007 | 04:16 PM
Vgm's Avatar
Vgm
Mass Airflow Sensor
I have 1988 GTA and as of recent ever so often the check engine light comes on and the engine lack a significant amount of power. Ill hit the gas hard and it barely if at all increase speed. I hooked it up to a diagnostic computer and found it was the mass air flow sensor. I have a bosch in there now Im not sure if its the stock one or not but Im going to have to replace it and dont know what to go with. Ive seen one from granatelli and one posted here called a wells su145. Any suggestions or help would be much appreciated.
Old May 21, 2007 | 01:26 AM
Guest
Guest
Posts: n/a
Re: Mass Airflow Sensor
I'd start with replacing the mass air power and burnoff relays first. Also check the setting of the throttle position sensor. Do both of those before you even think of replacing the mass air sensor, thats likely not the problem.
Old May 21, 2007 | 05:49 AM
Vgm's Avatar
Vgm
ok thank you
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
wstephan96
Sep 25, 2015 04:28 PM
