cough and sputter at low rpm during accelleration...help
Old May 20, 2007 | 08:50 PM
simster571's Avatar
my 96 T/A has a nasty cough/sputter, almost like its missing sound and feel to it when i try to accellerate any at all except for the "just resting the foot on the pedal" accel. it only occurs at low RPM's, like under 2500. if im over that, it runs perfectly fine. I read some other posts on here and seems one guy fixed it with changing his plugs and wires, which i will do tommarrow, and my mechanic said to run some fuel injector cleaner in it on the next tank of gas, which im running through it now. I have also changed to oil recently, which suprisingly seemed to help a little bit.
Has anyone else experienced this? How did you fix it? Whats wrong? Any tips or thoughts on what you guys think it could be and what I need to change out or do?
Thanks alot
Old May 20, 2007 | 09:17 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: cough and sputter at low rpm during accelleration...help
its a 96 no one will touch it out of principal... there is a 4th gen board that could help you better anyway
Old May 20, 2007 | 09:26 PM
simster571's Avatar
but you dont have any ideas on what it could be? all im looking for are suggestions...comments..anything.
Old May 20, 2007 | 10:26 PM
Car: 91 RS
Engine: 350 vortec
well look at plugs and replace as needed and wires... and it is always good to look at the condition of the opti spark junks
Old May 20, 2007 | 11:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Try ls1lt1.com.
Cornholio7979
Sep 20, 2018 02:31 AM
jklein337
Sep 19, 2018 06:23 PM
777Shock777
Oct 29, 2015 04:30 PM
Prodigious
Oct 4, 2015 11:20 PM
Jake_92RS
Aug 17, 2015 09:42 AM
