bad sending unit
Old May 21, 2007 | 06:50 AM
89irocTPI's Avatar
bad sending unit
Well one day i started my car and when i cut it off the pump continued to run so i looked at the oil pressure switch and unpluged it to kill the pump seems like whenever i hook it back up the pump runs. The pressure gauge itself is now pegged all the way down as far as it goes way past 0 is this a bad switch? the pump wont stay running either now.
Old May 21, 2007 | 12:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: bad sending unit
Replace it.
Old May 22, 2007 | 06:30 AM
89irocTPI's Avatar
is that the only thing it could be the oil pressure switch is grounded to the block correct?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Glowsock
Aug 26, 2015 12:28 AM
