please I still need help
Old May 21, 2007 | 07:07 AM
gargoyle725's Avatar
ok still cant figure out my 88 iroc 305tbi.I have tried everything. still when it starts the rpms go crazy up and down. Any suggestions would be great.
Any local Clearwater, fl guys that would like to stop by I would be very greatfull . Please help me get this thing back on the road before it goes to the scrap yard I cant be with out a car much longer.
Old May 21, 2007 | 07:08 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: please I still need help
when is the last time you did a tune up on it?
Old May 21, 2007 | 07:52 AM
promblem started last week it died driving ,i have since done cap, rotor,plugs ,o2 sensor airfilter, egm valve. Cleared all codes and still nothing. It is getting fuel and spark, fuel pressure is 12 psi. battery is good,
Old May 21, 2007 | 07:56 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Does it display an SES light? Could possibly be the throttle positioning sensor, or TPS for short.
Old May 21, 2007 | 08:11 AM
it does not show any codes now
what years could i use the tps from a may make a junk yard run because no one has them in stock . that way I can test it before I spend another $40
Last edited by gargoyle725; May 21, 2007 at 08:16 AM. Reason: Automerged Doublepost
Old May 21, 2007 | 08:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
https://www.thirdgen.org/tpimod2
This will show you how to test it without even bothering with a boneyard.
Old May 21, 2007 | 08:41 AM
i will try this now
Old May 21, 2007 | 08:48 AM
do you need 3 jumper wires and could you guive me a little more info on where to hook up vom. sorry I am auto mech challengened
Old May 21, 2007 | 08:54 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
https://www.thirdgen.org/forums/tpi/...tps+adjustment
Old May 21, 2007 | 09:13 AM
Wadebryant's Avatar
Testing with a VOM? Follow the tech article posted by Viprklr.
The TPS is located on the passenger side of the throttle body. Has two screws securing it, and one wired connector. Disconnect the wired harness, make your jumper wires, turn key on and test voltage reading while opening and closing the throttle.
If it's bad, you can probably find a replacement part at Advance Auto for around $20+-.
Good luck
Old May 21, 2007 | 09:36 AM
ok no jumpers unpluged key on I get 4.5 with pos on c and neg on a. aand b i get nothing with or with out junpers
Old May 21, 2007 | 11:07 AM
ok I got frustrated and removed the tps and it did not change to much it idled lower but still rough
Old May 21, 2007 | 11:48 AM
tps off car, jumpers between all 3 leads I get 4.99 volts with a and c and nothing with any other combo
Old May 23, 2007 | 03:38 PM
ok here is everything I have replaced
cap
rotor
plugs
tps
tps plug
fuel pump relay.
o2 sensor
air filter.
it ran last night befor i put the tps on then it would not start again so today I picked up the tps and still will not start.
if noone has any clues the tag is coming off and it will sit untill I have time aND money.
Old May 24, 2007 | 07:07 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Check the vacuum lines and replace the pcv valve and see what happens.
Old May 24, 2007 | 07:31 PM
would either of those keep it from starting
Old May 25, 2007 | 12:31 AM
if you had a big enought vacum leak then yes it could make it not start.
Old Jun 3, 2007 | 07:11 PM
ok just got help from a guy with a couple fbodies. He determined I had weak spark. if you hold the coil wire away from the cap it starts and runs fine. he tried a ne coil, new coil wire and it was still the same thing. any ideas
