does the coil need to be mounted?
Old May 22, 2007 | 11:32 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
i just finished putting my engine back together with the vortec heads and edelbrock performer rpm intake. the stock coil mounting location no longer exists and i need to mount it somewhere else. can i mount it on the firewall sideways? and i tried starting the car with the coil just sitting there but it wouldn't fire does it need to be mounted for the engine to run?
Old May 22, 2007 | 11:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, there isn't any path to ground through the case. Sounds like you've got something else going on.
Old May 23, 2007 | 12:15 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: does the coil need to be mounted?
Yea five7kid is right, something else is going on.
I have my coil sitting unmounted in a nice little
corner, unable to move.. Car starts everytime
and has no problems.
Sounds like a possible ground issue, or faulty
wiring at the coil terminal connectors.
I had a simliar problem, car wouldnt start.
I move the coil and jiggle the connectors,
tried to start.. it fired back up again!
Turned out to be a loose wire near the
connector boot that was replaced easily.
Old May 23, 2007 | 11:41 AM
johnnyboy's Avatar
i'm going to recheck all of the plug wires and make sure they're all in order, and then go over all of the connections and make sure they're tight. hopefully it'll fire up then. any ideas on where to mount the coil though?
Old May 24, 2007 | 05:41 AM
Damon's Avatar
You can mount those little stock-type coils in any position. They're not oil-filled like the old canister coils of yesteryear. A bracket hanging off the bottom lip of the cowl area is one I've done myself a few times.
Agreed, grounding the body of the coil is not necessary (although it couldn't hurt). When I'm testing/futzing around with different coils they often just get laid temporarily on top of whatever is handy for a few runs and I can't say I've had any problems doing that.
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
