Temp Gauge...
Old May 23, 2007 | 10:59 AM
CamaroLver's Avatar
Temp Gauge...
I have a 1991 Camaro Z28. At first start-up the temp gauge shoots all the way up then goes back down. I was told that this is normal. But while driving, it doesn't move at all. Just stays sitting at the bottom. It worked during the winter, but now won't move at all. Is this a problem with the temp gauge? I'm assuming it atleast somewhat works since it shoots up at start up, so what else could be the problem? What is the normal operating temperature for a Camaro?
Old May 23, 2007 | 11:03 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Temp Gauge...
Get a new sending unit
Old May 23, 2007 | 11:12 AM
Re: Temp Gauge...
Make sure the wire is plugged in
Dark green wire, sending unit is in driver's side head between #1 & #3 spark plugs
Old May 24, 2007 | 07:13 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: Temp Gauge...
I think sofakingdom meant passenger side between #5 & #7. When you replace it make sure you drain the coolant first, otherwise you're going to get a very unpleasant face wash.
Old May 24, 2007 | 07:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Temp Gauge...
No, he meant driver side between #1 and #3.
You don't have to drain all the coolant, just enough to lower the level to below the heads.
Old May 25, 2007 | 12:45 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Temp Gauge...
Passenger side is for the fan switch. Drivers side temp sensor is for the gauge in the dash.
When it grounds out it pegs to full hot.
Old May 25, 2007 | 12:51 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Temp Gauge...
i think you are thinking about the fan switch. lol
Old May 25, 2007 | 09:05 PM
Car: 1989 Camaro
Re: Temp Gauge...
I stand corrected! I can't believe I made a boneheaded mistake like that. Somebody smack me. I've been a bad monkey.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
