roller rockers
Old May 23, 2007 | 07:52 PM
89irocTPI's Avatar
roller rockers
Well ive been looking for a nice bolt onand ive decided to go with the jegs full roller rockers for 87-95 center bolt heads. My question is cani just bolt them in to replace the stamped steel ones or will i need new springs. i have springs but i heard that my 981 springs will need special retianers or something to run them so if possible i just rather not change springs.
Old May 23, 2007 | 11:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: roller rockers
Maybe put some car info in your sidebar so we can help you more.
But either way, you can use those rockers without any other changes, don't expect to gain any power though, they're not a great bang/$ modification.
Who told you that you need special retainers to run 981 springs?!? If you have those springs collecting dust in your garage, i'd put 'em on.
Old May 24, 2007 | 06:31 AM
89irocTPI's Avatar
Re: roller rockers
well i was going to sell them but everyone was like you need special retainers for those so nobody wanted them. My car is a 350 2 bolt main roller block (l98) stock heads and cam with a high rise holley intake holley vs 650 carb, full slp exhaust (the 1 3/4 headers), 3.27 gears, s-10 stall, and a superior shift kit.
Old May 24, 2007 | 12:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: roller rockers
Ok, so no TPI, but a carb setup?
roller rockers aren't a good next mod. I'd drop the money into a camshaft, and put those springs on. As far as I know, comp 981's are 1.25" OD springs, which fit into your stock pockets, and would work just fine with stock retainers. Even if they didn't, new retainers and locks are only like $50.
Old May 25, 2007 | 06:35 AM
89irocTPI's Avatar
Re: roller rockers
yeah i know it needs more cam i was looking at a 220 intake duration @.50 224 exhaust duration @ .50 and .474 lift with 1.5 ratio on both intake and exhaust with a 111 LSA
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
