Which water neck have you guys used? I got rid of both ports on my water neck so there is no need for that one. I would like to grab a chrome one but they only say -1965 or to 1975. I am assuming because of the emissions eqipment. My car is a carbed 305.
Yea i've got one.
One is straight, one is 45* angled.
Depending on how you route your upper rad hose, you could use either. I have the factory style preformed water hose, so I need to use the 45* ANGLED one. The straight one is for older trucks or something.
Use the rubber o-ring they give you, but just in case, maybe RTV the crap out of it. I like to use SS bolts to hold it down too, and use sealant on those bolts.
Also, use a ratchet (not just a screwdriver) to tighten the hose clamp. Tighten it until it almost breaks. Mine keeps slipping off, since the chrome is much more slippery than the stock rusted piece eh?
I used a water neck gasked with the oring tho. With just the o ring it kept leaking. Never had a problem with the water hose slipping off tho.
Quote:
It's best to check the sealing surface (neck to intake) for trueness before installing. The best way is to true up to ensure a good seal is to place the sealing surface on a belt sander to buff off the irregularities.Originally Posted by Gnarley_Boarder
Which water neck have you guys used? I got rid of both ports on my water neck so there is no need for that one. I would like to grab a chrome one but they only say -1965 or to 1975. I am assuming because of the emissions eqipment. My car is a carbed 305. Also, scuff the part of the neck where the hose attaches with scotch brite or sandpaper to roughen up the surface a little, in order to give the rubber hose something to grab ahold too.
That will usually guarantee a leak.Originally Posted by 1320_Guy
Hasent leaked a bit since/
