spark no fuel pump or injectors
Car: 1992 Pontiac Trans Am Convertible
Engine: 6.0l LQ4
Axle/Gears: 3.73 True Trac
I have a 1992 trans am 305 tpi my problem is I can crank the engine over and get spark at the plugs but the fuel pump does not turn on automaticly , but I can run the fuel pump primer wire to the battery and get the pump to run but even when the pump is running in this state it still does not start . I also pulled a plug to see if there was fuel and there was none. I checked power at the injectors and it is there while cranking. WHAT DO YOU GUYS THINK . It will fire with starting fluid.
92camaroJoe
Aug 13, 2015 06:07 AM
