where does chevy measure hp ratings??
Old May 25, 2007 | 02:18 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
wasn't sure where to put this but i am wondering. i read somewhere that chevy started measuring their hp ratings at the wheels?? don't remember where i read that but i was just wondering if that was true or not.
Old May 25, 2007 | 02:45 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: where does chevy measure hp ratings??
nope, they rate the HP at the flywheel.
Some cars, like the 98-02 F-Body's, were under rated from the factory and most of the cars put down the rated HP at the wheels. Maybe that is what you heard mentioned but it was changed a bit in the wording.
Old May 25, 2007 | 06:19 AM
Damon's Avatar
Yeah, they're rated at the flywheel but using SAE standards (which are a little more pessimistic than why most local dynos use which typically use a slightly different set of standards). THey're also rated with full engine accessories, air cleaner and intake system and full exhaust system. But still, it's a flywheel rating, although it definitely tends to be a much more conservative rating than what you will read about in your typical magazine engine build article.
The LS1 motors in 4th gen f-bodies were well known for being underrated by the factory. Rated a little over 300 from the factory they often put down almost that much to the rear wheels. The factory totally sandbagged on that one- those motors were making every bit as much power as the "350HP" LS1 in their big-brother, the Corvette. The crate motor version of the LS1, rated at 320HP, is likewise a lowball rating- several magazines tested them with headers, no accessories and a high flowing intake system and got almost 400HP at the flywheel.
Elephantismo
Feb 13, 2019 12:51 AM
87v6Bird
Jul 1, 2018 04:12 PM
69GTOby
Apr 18, 2016 02:34 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
84 TA NV
Sep 6, 2015 08:02 PM
