problem or not?
Old May 27, 2007 | 12:54 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
problem or not?
i have put together a 383 with a .480/.480 lift cam and 1.6 rockers. now i think my heads are set up fo about .500 max lift is this a problem? i dont quite remember if they are set up for more or not i bought them off ebay and forgot the lift specs but if it is .500 max then will cause what i am about to describe? i ask this becasue i keep finding out that after a little while i have valve taps and have to adjust them. this is the second time in about a thousand miles. i am also finding small amounts of metal shavings. i originally had a gear drive then went to a timing chain so im not sure if the metal is form that or am i destroying my cam with the 1.6 rockers. will going down to 1.5's help with this? this is the first engine i put together so im kinda new to all of this. any help is appreciated thanx vinnie
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
