Engine want start, maybe too hot: 208*F
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Is there a thermal switch which will not allow the engine to start if its too hot? I ran my scanner, the coolant temp is 208*F.
What else should I look for? The car has been running great, recently turning a 12.35sec 1/4 mile.
I turn the key and nothing happens, the starter motor will not engage or run at all. But I do have electric to run the power windos etc.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Engine want start, maybe too hot: 208*F
Let me guess: factory starter?
But no, there is no such switch.
Car: '87 IROCZ
Engine: 395 ZZ4
Well, after sitting for two hours, the car started right up. no problems and a good idle.
And yes its the original starter in the car. Maybe its time for a high torque starter. Thank you for the response.
theshackle
Mar 5, 2017 06:37 PM
