1987 z28 weird idle
Old May 30, 2007 | 05:53 PM
huffymaxx123's Avatar
1987 z28 weird idle
Hello Im new to the forums and hope someone can give me another direction to go.
I bought a 32,000 original mile 1987 Z28 the the 305 tunedport motor. The car at idle has a slight surge that is not consistant. At times its fine and others its rough. I have already replaced the fuel filter,factory plugs,wires and cap/rotor. I also change the air filters. I have put almost 8 tanks of fuel thru it and have also used concentrated cleaner in each tank thinking since the car was hardly driven that it may have alot of carbon build up. I have taken it to a chevrolet store and had a corvette specialist go thru it and he can find anything nd says its normal. Thru the exhaust you can hear small pops sometimes. Any info would be appreciated
Old May 31, 2007 | 10:16 PM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
Re: 1987 z28 weird idle
IAM HAVING THE SAME PROBLEM SOMETIMES MY CAR POPS THROUGH THE FRONT OF THE TPI AND OUT THE EXAUST ONLY SOMETIMES ''ITS NOT NORMAL CHECK YOUR FUEL PUMP OUT AND YOUR INJECTORS
Old May 31, 2007 | 10:24 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
your exhaust pops when you get off the throttle right? it happens some say it is normal... ever seen pro stock cars. they shoot a 3 foot flame in the turns off the gas that is the good ones of course never get off the gas long enough but are you getting a Check engine light? get the codes from that first if you are it usually wont tell you whats wrong but it will give you a idea
how big of a surge are we talking about 100 rpms or 5-600?
Old Jun 1, 2007 | 04:37 PM
The surges are only like maybe 100 rpm. There have been no codes. I did pull the air intake off and I see carbon on the flappers in the throttle body. This car is immaculate showroom condition. Would I be an idiot to take it somewhere and have a bilstein throttle body injector cleaning. They tried to sell this 2 me last time but I think they are a rip off. I have used injector cleaner in every tank of fuel so far and I am lost at this point. The only other thing I can think of is a poss IAC motor??? What do you guys think. thanks for your input
Old Jun 1, 2007 | 11:47 PM
Car: 91 RS
Engine: 350 vortec
yes you can clean the IAC out there is a tech artical on it and how to reset it... might do wonders...
Old Jul 9, 2007 | 09:54 PM
sergio's Avatar
Car: 91 T-am convertible
Engine: 5.0 TPI
Transmission: 5 speed manual
I have a similar problem.
Did you ever fix your problem? what was it?
Old Jul 23, 2007 | 12:26 PM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
Check the EGR for carbon build up and the type of EGR...Some are run by exhaust back pressure and cause idle problems,..which means taking a look at the cat for damage or plugged.
Take a squirt bottle of water, set it to SPRAY or MIST. Rev the engine to 2500 or 3000rpm. squirt the whole bottle{or two) into the intake while holding the rpm's. Take the EGR off, it should be full of carbon now....clean it and reinstall it. Do it over. The hydrogen in the water chemically reacts with the carbon splitting it apart and blowing it out the exhaust and some ends up in the EGR. I've been doing this on all my engines over the years....it keeps them clean.
Cleotiz
Jan 6, 2018 08:56 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
EFR2000
Aug 18, 2015 08:54 PM
