Vacuum Hose Diagram? (engine wont start)
Car: 87 Z28
Engine: 305 ci TPI
im not sure if this is the correct forum to ask this in, but does anyone have, or know where i can find, a Vacuum Hose Diagram, for an 87 305 TPI engine? we (my dad and i) spent the last month replacing the old engine and transmission, its finally done, the engine cranks over, but it wont start (its not getting any fuel to the engine, also we know the fuel pump isnt recieving a message to turn on and pumo the fuel,
we think it has somethign to do with the vacuum hoses maybey not being in the right spot, and possibly a wire is disconnected (we checked for litterally a good 3 hours yesterday, and the only wires disconnected were for the A/C and Smog pump, both of which are not on the car)
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Re: Vacuum Hose Diagram? (engine wont start)
Someone put a sticky here. I have seen a few request for this. This doc has them all.............
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Check the distributor. The car won't run the injector or fuel pump without reference pulses from the distributor.
Car: 87 Z28
Engine: 305 ci TPI
we figured it out, a fuse was blown where the switch would be, problem solved, and the thing runs, but the timing is way off, it feels way to slugish, apparently theres a tan and black wire (or somethign like that) that we need to find to adjust the timing, but we cant find the thing
Car: 85 Z28
Engine: LG4 modified
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
