Rev limit or ignition problem very fustrated help plz
Old Jun 1, 2007 | 02:00 PM
Destructive099's Avatar
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
Basically the car is running decent from idle-3k however once I hit 3700 rpm she stops as if theirs a rpm limiter, now ive heard rummers theirs rpm limits set in the msd distributer which if their is I cant find it. Ive also questioned myself if I should get a 6al box and maybe that would solve my problem? Just need some input this is driving me nuts b/c everything on the car is basically new and the engine has about 100 miles on her and has yet run good enough to be able to run on the road due to this problem
EDIT: Was just trying to log some data and held it at around 3700 rpms where it sounds as if the rev limit kicks in and seems im having some heat issues when this happens, for the wires had cought on fire at the spark plugs and had to be put out fast ;-) coolant temp by the way was only around 190
Old Jun 1, 2007 | 05:20 PM
Vader's Avatar
Re: Rev limit or ignition problem very fustrated help plz
The stock ignition system should be good enough to get you to the upper 4K range.
How is the valve timing?
Old Jun 1, 2007 | 05:28 PM
Tonysz383's Avatar
Car: 88 IROCZ 350
Engine: 355 cu TPI
Transmission: 4L60 w/ 3200 stall
Axle/Gears: 9 bolt W/370 gear
I had that problem at the track ones. I forgot to reconnect the brown wire when I re-time the car. With a timing light check and see how much the time is advance when you rev the engine.
Infested
May 22, 2018 11:56 PM
billybob6110
Sep 24, 2016 09:50 AM
db057
Sep 4, 2015 07:57 AM
Bryan F
Aug 27, 2015 07:28 AM
db057
Aug 22, 2015 08:17 PM
