Timing Issue
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Timing Issue
I unplugged the ESC Little Tan wire with Black Stripe.
The Timing Tab in on the Driver Side of the Block.
I set the Mark at 0* TDC, Then I Looked in the Spark plug Hole and theres the Piston. So The mark and Tab Are Right On.
I Start the Engine and check the Timing, and the Mark is way off.. I Timed it by ear, theres No popping and it revs/Idles Smooth..
I Noticed the the mark Is at the 12 O' Clock Position.... So Why is it Way over there?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Transmission: 4L80E/4L80E
Car: 1991 Camaro RS
Re: Timing Issue
Its all 305 Except the Engine Which is a 350. All the electronics are 305..
Do you Think That Im Not at the Firing TDC?
I do have a timing light.. I tried to use it, but it didnt Fire anywhere near the tab.. So I tried to get it at a good spot..
Re: Timing Issue
Seeing the piston is good; but hardly precise enough to verify the accuracy of the tab. When near the top, it moves very slowly as the crank rotates.
I'm going to go out on a limb (since that's where all the fruit is) and guess this is a stock crank damper and some sort of aftermarket bolt-on timing tab?
If you have that combo, then your "mark" is about 35° retarded from where it belongs.
So until you ACCURATELY find TDC with a piston stop or something, don't bother with the mark; just set it to where it runs the best.
Car: 1991 Camaro RS
Re: Timing Issue
Oh I see. Im On the wrong Stroke. I need to get a New Cover with the Top Center Timing Tab. I Hate it when people screw stuff up like that and dont say anything when you buy it.
Thanks Alot for the Help. I Guess I Can get by where its at for a few days..
theshackle
Sep 17, 2020 08:26 AM
