head gaskets
Old Jun 3, 2007 | 03:39 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
head gaskets
I'm deciding whether or not to go with a thinner head gasket. the kit i have for my 350 says approx. 9.35:1 comp with flat tops and 64cc heads. I've got 67cc S/R torquers that I'm having cleaned up, and i was wondering if it would be worth going with .020 head gaskets for some more power. I've got an xe268h cam installed, need to pass emissions, and don't really want to run premium. so, should i just stick with the standard gaskets, or get thinner ones?
Old Jun 3, 2007 | 08:08 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: head gaskets
well that will depend on if you have had the block decked to those pistons or not...
Old Jun 3, 2007 | 10:03 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: head gaskets
Keep the thicker gaskets if you don't want to run the risk of needing premium. Depending on the thickness of the ones you have now, if you run .02 gaskets, you could increase your compression ratio to the point of needing to run it. The power gains are negligible anyhow, I say you keep the 9.3 ratio and run regular/plus with the way gas is now.
Old Jun 3, 2007 | 10:08 PM
Car: 91 RS
Engine: 350 vortec
Re: head gaskets
but the added quench depending on what his is at with the replacement gaskets would deff be a benifit and help reduce detonation with those flat tops
Old Jun 3, 2007 | 10:40 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: head gaskets
The numbers I ran show it will drop the C/R only from 9.35 to 9.1 using the 67cc heads instead of 64cc heads with an .040 gasket thickness. That's going to be in the upper end of 87 octane gas without a knock sensor anyway.
Old Jun 3, 2007 | 10:41 PM
84 t/a 5.0's Avatar
Re: head gaskets
yeah, the cam isn't that big to need the higher compression, i think i'll stick with the standard gaskets. thanks for the help.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
