Head Bolts TTY?
Old Jun 3, 2007 | 09:01 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Head Bolts TTY?
Just wondering if the head bolts on my 305 are torque to yield or can I reuse them?
Old Jun 3, 2007 | 09:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Head Bolts TTY?
nope, you're good to go. I'd recommend you buy some washers though, helps with the clamp load. Mr gasket, I forget the part #, but they're like $4.
Old Jun 3, 2007 | 09:50 PM
Shift06's Avatar
Re: Head Bolts TTY?
Thanks for the info. It says I am supposed to use sealer on the head bolts, should I? And what kind of sealer do they mean?
Old Jun 3, 2007 | 11:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Head Bolts TTY?
The head bolt holes are drilled through into the coolant jackets around the cylinders, so sealant must be used. Liquid teflon works.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
