Begin with Headers and/or Intake?
Old Jun 4, 2007 | 06:41 AM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Axle/Gears: 4th Gen 10 bolt posi / 3.43
Soon I'll starting my engine rebuild with one of my 350's I have laying around and I'm looking to prep up my little 305 for the current meantime. I figured If i spend any money that will have to stay with the 305 it'd just be an Intake manifold and carb. I was thinking I'd put some headers (mid-range or long) on the 305 and reuse them on the 350 (350 block w/ LT1 heads). How does this sound and can I get by with it pretty simply? I figured a simple intake/exhaust upgrade on the 305 would help it out pretty well, from what I hear the exhaust is horrible on the L03. Any suggestions would be appreciated.
Old Jun 4, 2007 | 06:46 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Begin with Headers and/or Intake?
The general belief is to start from the rear and work forward.
Exhaust is a good place to start.
If you can't get the air out of the engine, you won't be able to get more in.
Old Jun 4, 2007 | 06:55 AM
F-Body Demon's Avatar
I put open headers and a carb on my LG4 and it rocks. Intake and Cam are next
Old Jun 4, 2007 | 11:44 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yes do your exhaust first. Biggest bang for the buck. After the exhaust then the intake system. If you do the intake first you won't get the maximum.
Old Jun 4, 2007 | 09:33 PM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Thanks for the feedback guys! I decided to start with the exhaust now.. I'm just worried about fitting issues.
Old Jun 5, 2007 | 07:40 AM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Forgot to ask: What kind of headers should I be looking at? Brand? Size? Going to keep it Y-pipe also.
Old Jun 5, 2007 | 01:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm partial to the Hooker 2055HKR. Best y-pipe out there; headers support stock to built engines. Some minor fabrication required to put on a non-TPI car (for the A.I.R. pipe on the driver's side). These are '86-'90 TPI single cat application headers, getting the rest of the exhaust for that application as well highly recommended.
Old Jun 6, 2007 | 06:30 AM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Will these preform better then long tubes?
Old Jun 6, 2007 | 06:46 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Longtubes - more torque
Shorties - less torque more hp
I went with Hedman longtubes.
Old Jun 6, 2007 | 10:01 AM
five7kid's Avatar
On an otherwise stock RS? Doubt you'd see the difference.
Shorties win the ground clearance contest every time.
Old Jun 6, 2007 | 12:20 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I have to agree with 5 7. I have shorties on a otherwise stock RS(besides a K+N) and don't notice much of a difference powerwise. Gas mileage went up a couple mpg. Engine definately breathes easier, but not really a seat of thepants difference.
Old Jun 6, 2007 | 12:36 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
i threw set of shorty headmens and a ypipe under my 89 rs and it made a little difference. formula wise the engine will breath better especially with the open element. btw its headers to tips WIIIDE OPEN!! sounds great
Old Jun 7, 2007 | 02:09 AM
+1 Open headers =
Im in love with the way they sound
Old Jun 7, 2007 | 06:28 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Until the rest of my exhaust gets here i'm running longtubes with header extensions and a lopey cam. Talk about vibration!!! My house vibrates.
Old Jun 7, 2007 | 03:28 PM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Well I see those headers have the A.I.R crap that came with the TBI but won't that be useless once my LT1 is built and swapped in there? I'm shooting for a 350HP motor also with the LT1 so would shorty's still help in that situation?
Old Jun 7, 2007 | 04:59 PM
five7kid's Avatar
That's approximately what my 350 is putting out (gross flywheel).
Old Jun 7, 2007 | 05:27 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
i have headmens w/o air
LT1Formula
20
Nov 14, 2015 12:02 AM
Ducati900ss
Sep 2, 2015 09:05 AM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
