What do you think I will put on the ground?
Old Feb 27, 2007 | 07:03 PM
redtail2624's Avatar
Car: 88 TA
Engine: 383 Converted LT1 intake
Transmission: TH350 3500 stall
Axle/Gears: 12 bolt 3.73's
My setup is.....
383 c.i LT1 intake port matched to angle milled Trick flow 195cc aluminum cylinder heads, comp cams 230/236 .510/.520 max lift 114lsa cam, 10.1:1 compression on 25cc dished pistons, 5.7 rods, bbk underdrive pulley's, Cold Air intake, hooker long tube headers, mufflex off road y-pipe, flowmaster catback, th-350 trans with 3500 stall , 12 bolt rear with 3.73's. And its going to be Dyno tuned, Any estimates as to what kind of power I might get on the ground? Thanks.
Old Feb 27, 2007 | 07:11 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Old Feb 27, 2007 | 08:27 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
I will say thats about right. Its all a guess but I will throw out 335rwhp and 390+rwtq as a guess.
Old Feb 27, 2007 | 09:27 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Let's see. Auto with 3500 stall. I will say 355rwhp.
Old Feb 27, 2007 | 09:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Hmm, since you're getting it dyno tuned then you'll actually give an answer, this intrigues me.
I'll say 310RWHP, 375RWTQ
Old Feb 27, 2007 | 10:00 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
315-330rwhp, 350-380rwtq..
Old Feb 27, 2007 | 10:20 PM
Car: 88 TA
Thanks for the input everyone , I will definatley let you all know what the official numbers are when I get her tuned, but unfortunately there is still a couple feet of snow on the ground so I dont think ill be going any were for another 6 to 8 weeks. Honestly I cant wait!!
Old Feb 27, 2007 | 10:31 PM
5678TA's Avatar
Car: 1984 Trans Am
thats nothing, i have to wait till the middle of JUNE to even see my car.. let alone drive her.. i will be getting my dyno numbers sometime in august.. hoping for around 400rwhp
Old Mar 9, 2007 | 09:55 AM
Steve40th's Avatar
My 396 LT1 with the same cam, 11.1 to 1 compression , CNC ported LT1 heads, ported intake, 58mm throttle body, Long Tubes(1 3/4), 2800 stall, 3.75 gears in my Vette tuned by PCM forless makes 425rwhp/428ft/lbs tq.
Still working on open loop tune, but I think you will make close to 400rwhp.
Old Mar 9, 2007 | 06:35 PM
Dialed_In's Avatar
You've got a full point more compression, more cubes, CNC'd heads and lower stall. He wont make that much. Not to mention the power curves are going to be completely different between your two motors.
Remember though, HP numbers aren't everything.
Old Mar 9, 2007 | 06:49 PM
Steve40th's Avatar
Yep, I have a whole 13 cu inches, and his Trick Flow heads are better than mine, as mine are factory cnc'd heads. I think the Trick FLows are pretty darn good, and the point of compression helps a little bit, true.
But a hot cammed LT1 makes 350-360hp with factory stall or six speed, with headers. So, I think the 310-330rwhp is a little low. Actually very low.
Just my opinion though.
Old Mar 9, 2007 | 09:16 PM
Dialed_In's Avatar
We'll see. I'm sticking to my 320. His setup is very similar to mine, but he's got a bunch of power robbing goodies.Mine made 425fwhp and 360rwhp. Bolt on all the pulleys, LT1 intake, higher stall converter a Ypipe and a 12 bolt and he'll be down around the 320 mark.
Old Jun 6, 2007 | 03:44 PM
Car: 88 TA
Re: What do you think I will put on the ground?
Well went to the dyno tune today and got it all tuned up. When we got there we did a base run and had a 14.5 a/f ratio and put down 308 hp and 322 torque it looks like converter flash . Then we got the a/f ratio right at 12.8 to 13 and we put down 315 hp and 374 torque which looks like some converter flash or something. The average torque went from 290 (first run) to 300 (second run). So i was basically told that with the automatic and the 3500 stall converter that i was not going to get accurate hp and torque numbers. Which looks like was true because those numbers are way low, my buddys stock lt1 with a ram air setup long tube headers and exhaust puts 306 hp down through a 6 speed , And there is no way im only putting down 10 more hp with a fully modded 383. And they were both on a dyno jet.
Old Jun 6, 2007 | 03:55 PM
ssean92's Avatar
Car: sold
I know that that stall is sucking alot of power from ya, so with that said the #'s dont look bad at all, but the true test will be at the track
Old Jun 6, 2007 | 09:55 PM
Car: 1989 GTA
Engine: 369 TPI
Your numbers are low. Did you degree the cam in? Was this on a Mustang dyno? Something is not right. The high stall will eat up power but I have one too. Can you post the dyno graph?
I will enable my signature so you can compare things. By the way do you know what your dynamic compression ratio is? Mines at 8.5:1.
Old Jun 6, 2007 | 09:58 PM
Dialed_In's Avatar
A dyno is only as good as the tuner running it.
Take it to the track. I'm willing to bet the numbers aren't too far off.
Old Jun 7, 2007 | 02:26 PM
Car: 88 TA
My cam is degreed and it was on a dyno jet and my compression is 10:1. The tune was done by kennedy's dyno tune and im pretty sure he knew what he was doing.
Is my car suppose to put low numbers down then go really fast at the track???
Old Jun 7, 2007 | 05:39 PM
Car: 1989 GTA
Engine: 369 TPI
The track will tell the tale. Your mph will be a gage as to how much power you are making. The dyno is only a tool and the output will very from dyno to dyno. So as the above poster said take it to the track and let us know how you did.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
